A A A A Auteur Sujet: Problème codage VCDS  (Lu 8490 fois)
Hors ligne Antho
  • Motorisation: 2.0 TDI 140ch
« le: 19 mars 2015 à 11:54:48 »
Suite au changement du Gateway, pour l'autoradio RCD310 > Voici les défauts
Voici mon diag :
Monday,16,March,2015,17:21:13:10074
VCDS Version: Release 10.6.4
                Address 19: CAN Gateway       Labels: None
Control Module Part Number: 7N0 907 530 AN    HW: 7N0 907 530 AN
  Component and/or Version: J533  Gateway H56 1642
           Software Coding: 350000
            Work Shop Code: WSC 00000 000 00000
                      VCID: 7CF3F0C3467B
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 212382 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:15:14
Monday,16,March,2015,17:21:42:10074
                Address 42: Door Elect, Driver       Labels: 1K0-959-701-MIN1.lbl
Control Module Part Number: 1K0 959 701 E
  Component and/or Version: Tuersteuergeraet 09 0103
           Software Coding: 0000052
            Work Shop Code: WSC 00028 028 00001
                      VCID: 306B14F3DAB3
1 Fault Found:
        011 - Open Circuit
Monday,16,March,2015,17:22:11:10074
                Address 46: Central Conv.       Labels: 1K0-959-433-MIN.clb
Control Module Part Number: 1K0 959 433 B
  Component and/or Version:    KSG              0201
           Software Coding: 00E802087F2D8404084A0100
                      VCID: 2F69178FC78D
1 Fault Found:
        011 - Open Circuit
Monday,16,March,2015,17:22:43:10074
                Address 52: Door Elect, Pass.       Labels: 1K0-959-702-MIN1.lbl
Control Module Part Number: 1K0 959 702 E
                      VCID: 316D11F7D1B9
1 Fault Found:
        011 - Open Circuit
Monday,16,March,2015,17:23:29:10074
                Address 56: Radio       Labels: 5M0-035-1xx-56.clb
Control Module Part Number: 1K0 035 186 AA    HW: 1K0 035 186 AA
  Component and/or Version: Radio RCD310  016 0049
           Software Coding: 0500040004
            Work Shop Code: WSC 01357 011 00200
                      VCID: 65C5B5A7D5F1
4 Faults Found:
00856 - Radio Antenna
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 212382 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:18:19
00821 - Antenna 2 for Radio (R93)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 212382 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:18:19
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 212382 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:18:14
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 212382 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:18:08
Monday,16,March,2015,17:29:13:10074
                Address 61: Battery Regul.       Labels: 1K0-907-534.clb
Control Module Part Number: 7N0 907 534     HW: 7N0 907 530 AN
  Component and/or Version: Batt.regelung H56 1642
           Software Coding: F000185A
                      VCID: F1ED51F79139
1 Fault Found:
02071 - Local Databus
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 212382 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:16:16
Hors ligne Meer
  • Véhicule: Golf V Plus
« Réponse #1 le: 19 mars 2015 à 12:31:04 »
Si ton adresse 61 est cochée, il faut la décocher.
Car il n'y a pas de (2eme) régulateur de batterie sur Golf 5. Avec notre génération de Golf, cette régulation se fait directement via le Gateway.
« Modifié: 23 mars 2015 à 20:41:59 par Meer »
VCDS
Hors ligne Antho
« Réponse #2 le: 19 mars 2015 à 13:41:11 »
Salut meer, merci pour ta réponse.
J'ai pas coché le 61, c'est ca le problème !
Il se met automatiquement !
Hors ligne Meer
« Réponse #3 le: 19 mars 2015 à 15:11:50 »
Ta version de Vag Com (10.6.4) a l'air trop ancienne pour bien paramétrer ton gateway.
J'ai déjà rencontré ce problème => http://www.golf5forum.fr/index.php?topic=43435.msg918309#msg918309
La version 10.6.4 reconnait tous les composants allant (fabriqués) de 1999 à 2010. Et comme ton gateway date très facilement de fin 2012, c'est peut-être pour cette raison que cela ne fonctionne pas.
Mais arrives-tu déjà à atteindre la liste d’installation du gateway?
« Modifié: 19 mars 2015 à 15:25:28 par Meer »
VCDS
Hors ligne Antho
« Réponse #4 le: 19 mars 2015 à 15:45:46 »
J'ai quand même accès au gateway avec la version actuelle de vcds.
J'ai mis la même configuration que l'ancien gateway concernant la liste d'installation !
Hors ligne Meer
« Réponse #5 le: 20 mars 2015 à 11:09:38 »
Ca me parait louche que tu avais le 61 d'activé avant  :gne: (même une Passat CC 2010 n'a pas le 61 activé!)
Mais alors qu'est-ce qui t'empêche de décocher le 61?
« Modifié: 20 mars 2015 à 11:13:43 par Meer »
VCDS
Hors ligne Antho
« Réponse #6 le: 21 mars 2015 à 11:54:13 »
Salut !
Nan ! j'avais pas le 61 avant dans mon ancien gateway !
Et dans le nouveau, je l'ai pas coché !
Et j'ai quand même cette notification !
Hors ligne Meer
« Réponse #7 le: 23 mars 2015 à 15:25:44 »
C'est un casse tête chinois ton truc  :bizarre1:
Donc, si je résume:
- Le 61 n'est pas coché (donc désactivé)
- Tu ne l'as pas coché non plus.
...mais il apparaît quand même dans ton scan! Là j'avoue je sèche. :bizarre1:
Regarde quand même ce tuto, j'ai l'impression que ton gateway provient d'un autre type de véhicule =>http://www.golf5forum.fr/index.php?topic=47380.0
« Modifié: 23 mars 2015 à 15:36:57 par Meer »
VCDS
Hors ligne Antho
« Réponse #8 le: 23 mars 2015 à 16:23:06 »
Voilà c'est ça !
Après mon véhicule fonctionne très bien pour l'instant !
Après sans erreurs c'est mieux !
Hors ligne Meer
« Réponse #9 le: 23 mars 2015 à 16:38:58 »
Ok, c'est claire, c'est mieux sans erreur.
Regarde le lien que je t'ai mis sur mon message précédant, peut être que ton gateway est réglé sur un autre véhicule (genre SUV ou haut de gamme).
J'ajoute aussi que ton gateway est très récent, donc tu auras probablement plus d'options que dans ce tuto.  :wink:
« Modifié: 23 mars 2015 à 16:41:17 par Meer »
VCDS
Hors ligne Antho
« Réponse #10 le: 23 mars 2015 à 16:45:35 »
Pas évident ton tuto ! c pas très clair
Hors ligne Meer
« Réponse #11 le: 23 mars 2015 à 17:26:13 »
Euh... t'es sur de savoir maîtriser Vag Com? Car y'a rien de compliqué à ce niveau là.
VCDS
Hors ligne Antho
« Réponse #12 le: 23 mars 2015 à 17:55:01 »
Oui t'inquiètes ! Mais y'a mieux comme tuto quoi !
Hors ligne andykp
  • Motorisation: 2.0 TDI 140 Sportline
« Réponse #13 le: 23 mars 2015 à 17:56:41 »
C'est gentil pour Meer  :D
Hors ligne Kenzo13
  • Pays: it
  • Motorisation: 1.9 TDI 105
  • Véhicule: Golf 5 confort
« Réponse #14 le: 23 mars 2015 à 18:01:35 »
Le tuto de Meer est simple net et précis...
