Bonsoir, j'ai un soucis sur le tiguan de mes parents, les 3 voyants sont allumés, comment fait-on pour lancer une regeneration, ou que faut il faire pour que ca revienne dans l'ordre?
Merci d'avance
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Wednesday,23,January,2013,16:48:39:10074
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 1C 22 25 42 44 46 52 53 56 62 72
VIN: WVGZZZ5NZ8W033191 Mileage: 57910km/35983miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 GT HW: 03L 906 022 G
Component: R4 2,0L EDC G000SG 2348
Revision: --H01--- Serial number: VWX7Z0H13NF0K7
Coding: 0000172
Shop #: WSC 00011 888 181093
VCID: 7DF5FDC75D61
1 Fault Found:
009263 - Diesel Particulate Filter (Bank 1): Restricted/Clogged
P242F - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 57912 km
Time Indication: 0
Date: 2000.00.00
Time: 15:42:39
Freeze Frame:
RPM: 920 /min
Speed: 0.0 km/h
Pressure: 5 mbar
Hex Value: 0xFF01
Temperature: 48.0°C
(no units): 51.0
Mileage: 80 km
Readiness: 1 1 0 0 1
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6CD3C083361B
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
000 - - - Intermittent
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2QC603
VCID: FDF57DC7DD61
1 Fault Found:
00532 - Supply Voltage B+
015 - Cannot Be Tested at this Time - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111111
Fault Priority: 3
Reset counter: 22
Address 53: Parking Brake Labels: 5N0-907-801.lbl
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H08 Serial number: 00000000036177
Coding: 0000057
Shop #: WSC 01324 785 00200
VCID: 2E570A8BC087
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 158
Mileage: 57483 km
Time Indication: 0
Freeze Frame:
Voltage: 10.90 V
Count: 52
Speed: 0.0 km/h
Hex Value: 0x12E0
Hex Value: 0x0001
Hex Value: 0x0101
