bon,j'ai trouver ça:
01299 - Diagnostic Interface for Data Bus (J533)
01299 - Diagnostic Interface for Data Bus (J533): No Communications
Possible Symptoms
* Warning Lamp On
Possible Causes
* Wiring Harness Issue
* Defective Control Module
Possible Solutions
Notes
* If the fault is only found in one control module, then most likely that module is the issue. However, if the fault is found several different control modules, then the CAN Gateway could be the issue.
si quelqu'un comprend quelque chose ?
je compte partir en vacance avec mon véhicule,ça peu avoir un incident sur la voiture.
