A A A A Auteur Sujet: [REF] modules électroniques sous le volant  (Lu 17868 fois)
Hors ligne StarGuest
  • プレイステーション
« le: 19 novembre 2010 à 11:04:29 »
Pour éviter de devoir à chaque fois faire une recherche:
 :!: C'est le Module 16 qui contrôle le MLF,l'ODB et le cruise Control. En fonction de la gamme voici les possibilités :
 :arrow: Lowline: Module de base. Ne supporte aucune des trois options
 :arrow: Midline: Cruise Control & ODB
 :arrow: Highline: Cruise Control, ODB et Multifonction
Citer
Citation
Type I (Compatible to Slip Ring: 1K0-959-653, 1K0-959-653-A)
Lowline
Part Numbers: 1K0-953-549
Supported Features: None
Midline
Part Numbers: 1K0-953-549-A
Supported Features: Cruise Control, Trip Computer
Highline
Part Numbers: 1K0-953-549-B, 1K0-953-549-D, 1K0-953-549-AM
Supported Features: Cruise Control, Trip Computer, Multi-Function Steering Wheel
Type II (Compatible to Slip Ring: 1K0-959-653-C, 1K0-959-653-D)
Lowline
Part Numbers: 1K0-953-549-E, 1K0-953-549-AE
Midline
Part Numbers: 1K0-953-549-F, 1K0-953-549-AF, 1K0-953-549-AP, 1K0-953-549-AQ, 1K0-953-549-BC
Highline
Part Numbers: 1K0-953-549-G, 1K0-953-549-AG, 1K0-953-549-AK, 1K0-953-549-AL, 1K0-953-549-BD, 1K0-953-549-BK
Citer
Steering Wheel Control Module Versions
(Redirected from VW Golf (1K) Steering Wheel Versions)
If in doubt check the Parts Catalog and order based on the VIN or based on the Original Part Number. In any case the Catalog should interpret the Part and provide you with a Part Number that superseded the Original Part Number. These final Part Number you will get is normally a Highline Module which you can verify based on the Table below.
Slip Rings
Type 1: 1K0-959-653 and 1K0-959-653-A
Type 2: 1K0-959-653-C and 1K0-959-653-D
Variants
Lowline: No additional Options/Features
Midline: Cruise Control, Board Computer
Highline: Cruise Control, Board Computer, Multi-Function Steering Wheel
Steering Angle Sensor
Yes: The Steering Angle Sensor (G85) is installed directly at the Steering Wheel/Slip Ring.
No: The Steering Angle Sensor (G85) is part of the Electro Mechanical Steering Assist.
Notes:
#1: 1K0-953-549-BC may have a Bug which doesn't allow Cruise Control Retrofitting, in such a Case you need to replace the Steering Wheel Control Module.
#2: Manual Transmission only
Control Module Part Number    Slip Ring    Software Level    Variant    Steering Angle Sensor    LIN Version    Notes
1K0-953-549    Type 1    SW 0030    Lowline    Yes    -    -
1K0-953-549-A    Type 1    SW 0030    Midline    Yes    -    -
1K0-953-549-B    Type 1    SW 0010    Highline    Yes    1.3    -
1K0-953-549-D    Type 1    N/A    N/A    N/A    N/A    N/A
1K0-953-549-E    Type 2    SW 0050    Lowline    Yes    -    -
1K0-953-549-F    Type 2    SW 0050    Midline    Yes    -    -
1K0-953-549-G    Type 2    SW 0050    Highline    Yes    1.3    -
1K0-953-549-J    Type 1    N/A    N/A    Yes    N/A    N/A
1K0-953-549-L    Type 1    SW 0040    Midline    Yes    -    -
1K0-953-549-Q    N/A    SW 0060    Highline    Yes    1.3    -
1K0-953-549-AB    Type 1    SW 0045    Midline    Yes    -    -
1K0-953-549-AC    Type 1    SW 0045    Highline    Yes    1.3    -
1K0-953-549-AD    Type 1    N/A    Highline    Yes    1.3    -
1K0-953-549-AE    Type 2    SW 0070    Lowline    Yes    -    -
1K0-953-549-AF    Type 2    SW 0070    Midline    Yes    -    -
1K0-953-549-AG    Type 2    SW 0070    Highline    Yes    1.3    -
1K0-953-549-AH    Type 2    SW 0070    Midline    Yes    -    -
1K0-953-549-AJ    Type 2    SW 0070    Highline    Yes    1.3    -
1K0-953-549-AK    Type 2    SW 0070    Highline    Yes    1.3    -
1K0-953-549-AL    Type 2    SW 0070    Highline    Yes    1.3    -
1K0-953-549-AM    Type 1    SW 0070    Highline    Yes    1.3    -
1K0-953-549-AN    Type 2    SW 0070    Lowline    Yes    -    -
1K0-953-549-AP    Type 2    SW 0070    Midline    Yes    -    -
1K0-953-549-AQ    Type 2    SW 0070    Highline    Yes    1.3    -
1K0-953-549-AR    Type 2    SW 0070    Midline    Yes    -    -
1K0-953-549-AS    Type 2    SW 0070    Highline    Yes    1.3    -
1K0-953-549-BB    Type 2    SW 0070    Lowline    Yes    -    -
1K0-953-549-BC    Type 2    SW 0070    Midline    Yes    -    #1
1K0-953-549-BD    Type 2    SW 0070    Highline    Yes    1.3    -
1K0-953-549-BE    Type 2    SW 0100/0101    Lowline    Yes    -    -
1K0-953-549-BF    Type 2    SW 0101    Midline    Yes    -    -
1K0-953-549-BG    Type 2    SW 0101    Highline    Yes    1.3    -
1K0-953-549-BK    Type 2    SW 0100/0101    Highline    Yes    1.3    -
1K0-953-549-BM    Type 2    SW 0101    Lowline    Yes    -    -
1K0-953-549-BN    Type 2    SW 0100/0101    Midline    Yes    -    -
1K0-953-549-BP    Type 2    SW 0101    Highline    Yes    1.3    -
1K0-953-549-BQ    Type 2    SW 0101    Lowline    Yes    -    -
1K0-953-549-BR    Type 2    SW 0101    Midline    Yes    -    -
1K0-953-549-BS    Type 2    SW 0101    Highline    Yes    1.3    -
1K0-953-549-BT    Type 2    SW 0101    Lowline    Yes    -    -
1K0-953-549-CA    Type 2    SW 0101    Midline    Yes    -    -
1K0-953-549-CB    Type 2    SW 0101    Midline    Yes    -    -
1K0-953-549-CC    Type 2    N/A    Highline    Yes    1.3    -
1K0-953-549-CD    Type 2    SW 0111    Highline    No    2.0    -
1K0-953-549-CE    Type 2    SW 0111    Highline    No    2.0    -
1K0-953-549-CF    Type 2    SW 0111    Highline    No    2.0    #2
1K0-953-549-CH    Type 2    SW 0111    Highline    Yes    1.3 & 2.0    -
1K0-953-549-CJ    Type 2    N/A    Highline    Yes    2.0    -
1K0-953-549-CK    Type 2    SW 0111    Highline    Yes    2.0    -
1K0-953-549-CM    Type 2    SW 0111    Midline    Yes    -    -
1K0-953-549-CN    Type 2    SW 0111    Midline    Yes    -    -
1K0-953-549-CP    Type 2    SW 0111    Midline    No    -    -
1K0-953-549-CQ    Type 2    SW 0111    Midline    No    -    -
1K0-953-549-CR    Type 2    N/A    N/A    Yes    N/A    N/A
1K0-953-549-CS    Type 2    SW 0111    Lowline    Yes    -    -
1K0-953-549-CT    Type 2    SW 0111    N/A    No    N/A    N/A
1K0-953-549-DA    Type 2    SW 0111    Lowline    No    -    -
1K0-953-549-DB    Type 2    SW 0070    Midline    N/A    -    -
Control Module Part Number    Software Level    Variant    LIN Version    Notes
3C0-953-549-A    SW 0010    Midline    -    -
3C0-953-549-B    SW 0010    Highline    1.3    -
3C0-953-549-H    SW 0015    Midline    -    -
3C0-953-549-J    SW 0010    Midline    -    -
3C0-953-549-AC    SW 0020    Highline    1.3    -
3C0-953-549-AJ    SW 0020    Highline    2.0    -
Control Module Part Number    Variant    Notes
5K0-953-549    Lowline    -
5K0-953-549-A    Midline    -
5K0-953-549-B    Highline    -
5K0-953-569-T    Highline    -
5K0-953-569-AA    Midline    -
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Wheel_Versions
  • プレイステーション
Re : Références modules électroniques sous le volant
« Réponse #1 le: 19 novembre 2010 à 11:18:26 »
En pdf si jamais le lien disparait.
Lien 1:
=>Miroir<=
