A A A A Auteur Sujet: [ Tuto ] Régulateur vitesse  (Lu 489069 fois)
Jarpy86
Re : [ Tuto ] Régulateur vitesse
« Réponse #135 le: 14 janvier 2011 à 15:43:25 »
Ca y est j'ai tout monté mais lors d'un passage vag com j'ai ça (désolé c'est long) :
Friday,14,January,2011,15:38:45:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ5W182288   Mileage: 66560km/41358miles
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC G000SG  6176
   Revision: 12345678    Serial number: VWZ7Z0D1260303
   Coding: 0000071
   Shop #: WSC 01279 785 00200
   VCID: 65CAB3CA933BD034
3 Faults Found
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
            P0672 - 000 -  -
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 176.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Bin. Bits: 00000100
                    Temperature: 0.9°C
                    Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
            P0674 - 000 -  -
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 176.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Bin. Bits: 00000100
                    Temperature: 0.9°C
                    Bin. Bits: 00110000
16952 - Cruise Control Switch (E45): Implausible Signal
            P0568 - 000 -  -  - Intermittent
             Freeze Frame:
                    RPM: 798 /min
                    Torque: 40.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021121
   VCID: 3A7030B64A058FCC
1 Fault Found
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67D6B9C26937C224
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001311268
   Coding: 20890F0600041800001400001400000000087B075C
   VCID: 39722FBA4F0384D4
   Part No: 1K1 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 07 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD03S3XH
   Coding: 0012343
   Shop #: WSC 01269 785 00200
   VCID: 2C5C06EEB051217C
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000021
   VCID: 3064129E9C79459C
1 Fault Found
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 851 H
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0003103
   Shop #: WSC 01293 995 89159
   VCID: 2D5A0BEA8B4B2874
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C1406ED
   Coding: 3D0F0B40070000
   VCID: 2952FFFABFA33454
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VDD 0716
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0169
   Coding: 0000052
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.2       1502
2 Faults Found
02546 - Steering Limit Stop
             Freeze Frame:
                    Mileage: 6560 km
                    Temperature: 16.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
             Freeze Frame:
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BK
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404084A01E010
   Shop #: WSC 00000 785 00200
   VCID: 7AF0F0B60A854FCC
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 3162179A97734C94
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio BVX       012 0022
   Coding: 0040400
   VCID: 2F6611E281475A64
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
End   ---------------------------------------------------------------------
C'est quoi toutes ces erreurs ? O.O
Merci d'avance car là je m'inquiète xD
« Réponse #136 le: 14 janvier 2011 à 16:34:05 »
elle est de quel année ta Golf ?
ta roule avec après avoir paramétré le boitier sous volant ?
donne plus de détaille sur ce que tu as changer et la référence de ton boitier sous volant .
Jarpy86
« Réponse #137 le: 14 janvier 2011 à 16:54:01 »
La golf est de 2005, j'ai changé le module sous le volant : 1K0 953 549 A, le slip ring vendu par la même personne (midline apparemment). Et le commodo que j'ai eu d'un touran, y'a juste les phares, les clignos et un switch ON/OFF pour le régulateur.
Quand y'a le contact le voyant régulateur fonctionne, dès que j'allume le moteur il s'éteind.
Oui j'ai roulé mais environ 20m quoi.
« Réponse #138 le: 14 janvier 2011 à 17:24:51 »
re
ok , c'est mieux
donc, il faut mettre le fil (c'est dans le tuto) qui doit te manquer et quelque message d'erreurs s'effaceront .
ta des erreurs qui parle de cylindre 2 et 4 qui doit surement correspondre soit aux bougies ou faisceau électrique.
Jarpy86
« Réponse #139 le: 14 janvier 2011 à 17:26:57 »
Oui pour le moteur ces erreurs apparaissent et disparaissent. Pour le fil je le trouve où ? Car je l'ai pas eu avec le kit que j'ai acheté. Chez vw ca se vend au détail ?
Merci de ta réponse.
EDIT : Je viens de voir les ref dans ton sujet, je vais chez vw dans l'espoir qu'ils soient ouverts... :D
« Modifié: 14 janvier 2011 à 17:31:45 par Jarpy86 »
« Réponse #140 le: 14 janvier 2011 à 17:31:29 »
http://www.golf5forum.fr/index.php?topic=17016.msg372669#msg372669
il faut acheter deux fil qui ne coute pas du tout chère chez VW
Jarpy86
« Réponse #141 le: 14 janvier 2011 à 18:31:17 »
Pas dispo chez vw avant mardi, il vendent chaque fil par 5 et payer 10fils à 1,65€HT l'unité ça me fait un peu mal quoi...
Y-a-t-il des gens qui ont utilisé un autre type de fil ?
Jarpy
« Réponse #142 le: 14 janvier 2011 à 21:04:18 »
re
tu prend un simple fil que tu dénudera de chaque coté sur 5 mm (environ)
tu les enfonces dans les trou qui sont prévu pour les cosses
ceci reste du provisoire mais sa fonctionne
Jarpy86
« Réponse #143 le: 15 janvier 2011 à 10:23:36 »
D'accord mais tant qu'à redémonter je passerais le fil qui va bien ! On soude n'importe quel coté de tes fameux fils ? Je comprends pas par ou tu fais passer le câble en partant du moteur.
Merci.
« Réponse #144 le: 15 janvier 2011 à 14:56:59 »
heu, regarde bien le tuto vers la fin, y a un PDF juste avant l'activation vag com
http://www.woofiles.com/dl-218641-hkQ1XBpR-G5GRAnachruesten.rar
Jarpy86
« Réponse #145 le: 16 janvier 2011 à 21:09:07 »
Oui j'ai regardé ton pdf mais je vois pas comment tu fais passer le câble du calculateur moteur à l'intérieur de l'habitacle. Tu suis les autres câbles ? A moins qu'une fois que tu aies ouvert le boîtier plastique du calculateur moteur tu aies accès à l'habitacle par là.
Je sais pas si je suis très compréhensible, désolé.
Merci pour tes réponses en tout cas.
Jarpy
« Réponse #146 le: 16 janvier 2011 à 22:48:48 »
regarde ce PDF là qui est aussi dans mon tuto
il coupe le fil à n'importe quel endroit (au milieu par exemple) et il faut les souder
une fois que tu ouvre le couvercle entre le compartiment moteur et l'habitacle, tu passe le fil (tu voit l'intérieur de la voiture)
et ensuite tu clips les cosses dans les fiches.
Jarpy86
« Réponse #147 le: 16 janvier 2011 à 23:12:59 »
Pour les fils j'avais compris. D'accord ! J'ai enfin compris par ou passer mon fil ! Merci encore, des news mardi soir !
« Réponse #148 le: 16 janvier 2011 à 23:13:58 »
re
de rien  :cool5:
Jarpy86
« Réponse #149 le: 18 janvier 2011 à 23:36:37 »
Bon j'ai fini le montage et lorsque je veux lancer VCDS j'ai ça qui apparaît : RT_USB.DLL : Time out. Bytes not found. puis une erreur -4. J'ai essayé en coupant le contact puis relancer le logiciel mais rien n'y fait.
J'aurais pu oublier de rebrancher quelque chose ou est ce qu'il y a une manip' connue à faire pour ce problème ?
Merci d'avance.
EDIT : Mon câble est surement hs, du coup je cherche quelqu'un qui aurait le vag com dans le 86.
« Modifié: 19 janvier 2011 à 15:38:36 par Jarpy86 »
